跳转到主内容
A fully-featured tablet for teens. The NABI XD Created by Fuhu inc. and was released December 2012.
3 个问题 查看全部
Nabi XD Black screen. Will not power on at all. Any suggestions?
The screen will not come on. When charging it goes from red and turns to green a couple hours later, so I'm sure charging isn't the issue. There is no way to reboot either since screen will not come on, I have tried that also. Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Make sure you are using a Nabi charging cable, then try a different outlet, or try using your USB and connecting it to a computer.
If that does not work, it seems that your device might need a screen calibration. To do so, follow the next steps:
Temporarily remove the rubber case.
Hold the Volume+ Button and the Power Button at the same time to trigger a touch screen recalibration.
If the screen is unlocked you will see a message. Follow instructions and please don't touch the screen until the calibration process is complete.
If the screen still does not respond, try performing a soft reset. To perform a soft reset, follow the steps in here: https://www.nabitablet.com/support/artic...
这个答案有帮助吗?
得分 0
添加一条评论
My nabi tablet is changing to red and green and I moved it from place to place and its been charging for 6 hours what should I do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
crazy4myphone 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 2,806
