跳转到主内容
加入维修社区 - 创建账户
无线连接并控制您的苹果电脑。
How to get the down arrow key into place?
the down arrow key has fallen out how do i get it back in??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
How do I fix it if the little plastic scissors are lost, and I only have the top?
完成的
添加一条评论
4个答案
已选择的解决方案
If the little plastic scissors are still in place just press it back on. Have look at this video. It's a MacBook there, but the procedure is the same.
这个答案有帮助吗?
得分 3
添加一条评论
You'll not be able to get the key working again if you dont have the white scissor clip that goes underneath. You can often buy keycaps on their own. But you'd need to identify which version of clip you have, as there are different versions depending on the manufacturer at the time.
if its one of the aluminium keyboards, then it will usually be either Type F or Type H.
(these are not identified by Apple, as they didn't start providing keycaps until 2015. We've come up with our own identification charts.)
here is a link to help identify which type you have.
If you then click on the type you have, you will be taken to the listings for that type. We sell every key with a white scissor clip, so you can replace both if need be.
http://www.thebookyard.com/apple-keycaps...
I hope this helps.
这个答案有帮助吗?
得分 3
1条评论:
My left arrow key fell off and I can only get one side of it on but the other side with the sliders I think is broken
完成的
添加一条评论
See step #15 & 16 of the tear down I did on this keyboard to understand how it works:
Apple Wireless Keyboard (A1255) Teardown
这个答案有帮助吗?
得分 1
添加一条评论
On my Late 2011 MacBook Pro (type F), I am having a similar problem, but I have the scissor mechanism in place. I am just not able to get the up arrow key to snap in place. Please review this video and let me know if you see any issues and/or have advice on how to get the up arrow key to snap in place. Thanks!
这个答案有帮助吗?
得分 0
3条评论:
its hard to see it clearly, but the bottom left peg may be damaged on the white scissor clip.
We class this keycap type as Type-G on our system (type F on our site is for the earlier MacBook range, not the MacBook pro from 2011)
But if it still doesn't work, i'd take a look at the clip underneath the black keycap, as its really common for them to get damaged
完成的
Thanks @thebookyard. It is hard to see (even in person), but I believe you are correct. Fortunately, I had access to another old MacBook Pro and was able to snag the up arrow key and scissor clip / assembly. This one worked.
完成的
Great to hear. Glad you got it sorted in the end
完成的
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 71
总计 24,115
