跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Can I upgrade my MBP Mid 2010 with Samsung 850 Pro SSD
Hello,
My 500gb HDD just failed on me so I am taking the opportunity to smack in an SSD into my Mid 2010 MBP and do a clean install of the OS. Does the Samsung 850 Pro(512GB) compatible with my MBP? Anyone out there with the same MBP model upgraded theirs with the 850 Pro? Any other brands/model that I can look in to if its not compatible?
Additional information:
  • Macbook Pro 6,2 (Mid 2010)
  • Intel core i7 2.66GHz
  • 8GB Ram
  • NVidia Geforce 330M
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
To start with you'll need to follow this IFIXIT guide: MacBook Pro 15" Unibody Mid 2010 Hard Drive Replacement to replace your current drive with a SSD.
As to who's SSD: We have mostly been using Samsung's EVO SSD's We don't use the Pro version. While many claim the Pro's speed and longer warranty is better. In the real world the EVO will serve you just as well at a lower cost. Here's a good write up: Samsung 850 PRO 2TB SSD Vs Samsung 850 EVO 2TB SSD while they are biased to the Pro, our user's experience over two plus years of use suggest the EVO was just fine.
The only thing here I do strongly recommend is you run the latest version of Yosemite (10.10.4 or newer) as it has TRIM services natively. You'll need to follow this: How to enable TRIM on third-party SSDs in OS X.
You'll want to get a large enough drive so 1/4 to 1/3 of it is kept free once you install all of your stuff. If you are finding the price of the SSD is getting too high for the size you need you may want to think about a SSHD drive like Seagate's or a dual drive like Western Digitals Black2 drive instead.
Don't forget to make sure your systems firmware is up to date before you start. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers
So the bottom line here is: The water is just fine which ever SSD you go with ;-}
这个答案有帮助吗?
得分 9
7条评论:
Update: Western Digital is no longer selling the Black2 drive.
完成的
Yes. Working very well on my MBP mid 2010, i7 2.66, 8 GB RAM.
regards
完成的
Hi, I can confirm it works just fine. No idea on Evo vs. Pro, I just got a good deal on the Pro and got a 512Gb version. Have it for 6 months in my mid 2010 15" and it's lovely.
完成的
Will it work for the 13" model 2010 MBP 2.66ghz?
完成的
Mark - The Samsung 850 series (EVO & Pro) have been replaced with a newer 860 series Samsung 2.5" 860 EVO
There is very little difference between the 850 & 860 other than the flash chip architecture. Both used the same Samsung Controller logic and both will work in any MacBook Pro which supports a 2.5" SATA drive.
完成的
显示更多的2条评论
添加一条评论
Hello I’m about to order the newer samsung 860 evo for a macbook mid 2010, I guess it will do just as well as the 850?
这个答案有帮助吗?
得分 1
3条评论:
Yes! You'll be fine. I do recommend you replace the HD SATA cable with a newer version as these tend to fail after awhile.
完成的
@danj I was fine and then the cable failed as you predicted :P
I should have changed it back then with the HDD but no harm done anyway.
完成的
I bet your heart missed a beat or two when it happened ;-}
完成的
添加一条评论
添加你的答案
rdknp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 37,343
