跳转到主内容
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
My pc did not recognize my LG G3 D855
HI ALL
I HAVE LG G3 D855 WHEN I POWER IT ON I GOT A MeSSAGE " BOOT VERIFICATION VERIFY .
I WANT TO RECOVER IT BUT WHEN I CONNECT IT TO MY PC BY USB CABLE IT IS NOT DETECTING I TRY SOFT AND HARD RESET BUT NOTHING.
THANK YOU ALL FOR HELPING.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
I have this problem too. My pc does not detect my Studio 6.0 HD phone when I connect it. So far I have been unable to download any picture via USB cable.
完成的
Hello Friend
SO FAR DID YOU FIND ANY SELUTION?
THANK YOU
完成的
maybe...
go to website of lg. go to service - update software. download and folloew all insturktions for updating software, so you get the newest drivers and how you have to connect.
or
set the usb-connection to different modes
完成的
添加一条评论
1个答案
最有帮助的答案
Hello tdye08,
Try to enable USB debugging first,
  • From a Home screen, navigate: Apps > Settings > Developer options.
  • Ensure the Developer options switch (located in the upper right) is turned on .
  • Tap USB debugging to enable
If Developer Options are unavailable,
navigate: Apps > Settings > About phone > Software info then tap Build number seven times.
Cheers!
这个答案有帮助吗?
得分 1
2条评论:
Hi Friend
so i cano't arive to this situation.
Thank you
完成的
Got it. it seems to be your boot partition corrupted. you will have to flash you phone or update firmware from SD card if available
完成的
添加一条评论
添加你的答案
tdye08 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 6,662
