跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
Do I need an in-line digital thermal sensor for 21.5 iMac(mid 2010)?
A few sites I've visited say that you need an in-line digital thermal sensor to prevent iMacs turning on its fan at full blast when replacing the hard drive with a third party SSD.
Is this the case when replacing the optical drive with an SSD rather than the hard drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
First, here is the IFIXIT guide for the dual drive setup: Installing iMac Intel 21.5" EMC 2389 Dual Hard Drive. While it implies dual Hard Drives it also will support a SSD instead.
If you jump down to Step12 here is the point you take the optical drive thermal sensor off the optical drive and then carefully place it back onto the drives case. This will preserve the SMC signaling so the fans will not go into safe mode (running at full blast).
If you decide to replace the HD with the SSD. You'll need to buy a replacement thermal sensor as the built-in sensor in the hard drive will now be missing. What I do here is get an extra optical drive sensor cable, Apple P/N: 922-9624 Cable, Temp Sensor, Optical Drive to use instead of the drives sensor. Follow this IFIXIT guide for all of the details: iMac Intel 21.5" EMC 2389 Hard Drive Replacement.
iMac Intel 21.5" EMC 2389 硬盘图片
指南
iMac 因特尔 21.5" EMC 2389 硬盘更换
难度:
中等
45 minutes
iMac Intel 21.5" EMC 2389 Dual Drive图片
指南
Installing iMac Intel 21.5" EMC 2389 Dual Drive
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your help
完成的
添加一条评论
Hi Dan,
Is it possible to use one Apple P/N: 922-9624 Cable for the Optical Drive and other Apple P/N: 922-9624 Cable for the SSD disk?
Gracias!
这个答案有帮助吗?
得分 1
9条评论:
"If you decide to replace the HD with the SSD. You'll need to buy a replacement thermal sensor as the built-in sensor in the hard drive will now be missing. What I do here is get an extra optical drive sensor cable, Apple P/N: 922-9624 Cable, Temp Sensor, Optical Drive to use instead of the drives sensor."
完成的
Thank you Dan.
And is it the same using Apple P/N: 922-9624 cable or using OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive.
Could I still use iStats to get the temperature from the NEW SSD with both cables?
Gracias
完成的
I prefer the OWC in-line sensor, at its easier to apply. The Optical drive sensor doesn't mount as cleanly.
Software doesn't really get into the picture here.
The sensor talks to SMC, SMC is polled by the OS and any 3rd party app polls the OS for the data.
完成的
Great!
I´m a bit afraid of breaking sth, hope not (Any advice?). As I´ll touch iMac internally for the first time, is there any chance to update Bluetooth to use airdrop without problems?
Here is my HW, sorry it´s in Spanish.
BLUETOOTH
Compatible con Bluetooth LE: No
Compatible con Handoff: No
Compatible con Instant Hotspot: No
Fabricante: Broadcom
Transporte: USB
Chipset: 2046
Versión del firmware: v208 c518
WIFI
Interfaces:
en1:
Tipo de tarjeta: AirPort Extreme (0x168C, 0x8F)
Versión del firmware: Atheros 9280: 4.0.74.0-P2P
Modos PHY compatibles: 802.11 a/b/g/n
Canales admitidos: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140
Wake on Wireless: Compatible
AirDrop: Compatible
Gracias.
完成的
Your system appears to be AirDrop: Compatible so I'm not sure what you are asking.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Med Okonta 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 19
总计 3,557
