跳转到主内容
7" multimedia tablet by Barnes & Noble, released in November of 2011. Fixes are easy and require simple prying tools and screwdrivers.
20 个问题 查看全部
How come my nook won't come on?
I believe my nook tablet is bricked but I've already tried several ways to unbrick the device. I've tried to download software onto a micro SD card and then put the SD card in the tablet multiple times with different suggestions that were suppose to fix it but it did not fix the device. But before I did this I tried to factory reset by holding the power button and n button down. I've even tried just to press the power button to turn it on (even though that was quite obvious) and it didn't work. I've had one problem in the past where it wouldn't go to the home screen it just loop in the first few screens when you boot it up. But the factory reset fixed it. My nook is also about 2-3 years old. So do you know how to fix it or where I could take it to get fixed, if so it would be greatly appreciated because I'm quite ready to just get a new tablet and throw this one away.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
I also have a problem turning my nook off. I googled it and it says there is a button on top of nook. There are two buttons on top right and all they do is in one button increases the volumn and one button decrrases the volumn.
完成的
Please tell me how to turn my Nook on and off.
完成的
添加一条评论
1个答案
已选择的解决方案
Rose Lucas, first you want to make sure that you charge your Nook's battery. Leave it on the charger for a good while. After that, I'd try a complete reset by removing the Nook's battery, Then leave the battery out of the Nook for at least 10 seconds. After that replace the battery in the Nook.Restart it. Press and release the power button to restart it and allow it to fully boot before using it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rose 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 9,893
