Carburetor spitting gas - have already replaced Carb!
Hello all...
Well, after weeks of trying different things, I finally coughed up the cash to get a replacement carb and I have the same issue after I cleaned it. Here's the background:
- This is an 18 y/o Craftsmand 19.5 riding mower
- Problem started with coughing carb, no power
- Replaced air and fuel filters and plugs (while I was out, changed Oil as well)
- Same issue; low power, coughing
- Took carb off and cleaned thoroughly; all jets clear, gaskets were old (never replaced)
- Started well, but gas vapor through top of carb. Engine would choke and die when i put Air filter and associated housing on
- Took back apart and tried again. When Mower was driven under load, engine would sputter and die after a few minutes
- Bought the appropriate repair kit. Replaced all gaskets, needle, valve, etc. Same exact issue with no improvement
- I finally bought the entire carb and put it on today. Same exact problem.
Seems like there is too much air and its spraying the gas out the top? I really don't know what to look at this point. There aren't alot of options to adjust air/fuel on this. Any ideas would be helpful.
Thanks
Sounds more like a timing issue. What engine does it have and, if you can get a model number of the engine, we might find a few things to help you out.
由 oldturkey03 完成的
It's a Craftsman Model 917.270810.
Thanks
由 Ernst Renner 完成的
