跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36474 个问题 查看全部
问题已关闭
Still need to charge phone every day
Thought the new battery would last longer??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could try the following procedure to re-calibrate the battery:
  • Use the iPhone until it shuts off itself, due to low battery (the battery should go down to 1% before the phone shuts off).
  • Here is what you need to do if your iPhone shuts down too early (like at 20-30%):
  • connect the phone to a charger for just a minute or 2, or wait 15 minutes, then reboot the phone (hold HOME and SLEEP until the Apple logo appears).
  • After the phone shuts down, leave the phone sitting 6-8 hours (or overnight) without charging it.
  • The next morning, connect the phone to a charger and charge it back up without interruption to a full charge of 100%.
  • IMPORTANT: Leave the phone connected to the charger for 1-2 more hours AFTER your reach 100%.
  • Reset your iPhone:
  • Hold both home and power buttons until the iPhone restarts itself, ignore the "slide to power off slider", and let the iPhone restart itself.
Your battery should now be re-calibrated and hopefully last longer.
Also check for background apps and make sure you use the latest iOS.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 52
