跳转到主内容
加入维修社区 - 创建账户
全新的 N 系列笔记本电脑采用 ATI Stream GPU 通用处理技术,带来更快的性能。这些技术与图形优化套件 Video Magic 协同工作,能够加速多任务处理并实现更高质量的多媒体效果
Screen won't come on
The computer powers on but the screen won't come on. What can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Hi, i have the same problem, the power light comes on but no video, no fun, no noise nothing, i´ve tryed batery out, change memory, change charger but nothing, only light on.
Can someone give me some help??
Regards.
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
这个答案有帮助吗?
得分 3
6条评论:
Hi Jim and thanks for your attention, well i do what you tell me but nothing, only power light on, and no more activity.
Any ideas??
Regards.
由完成的 分享
@mebini Bruno was there any problems with the machine leading up to the no start condition? Do you get post beeps at all? Did the laptop get damaged in a fall or did you get it wet at all? is the power adapter jack loose at all ? When the machine is charging do you get the normal lights?is the center post of the power jack loose at all (in the laptop)? The more we know the more we can help
由完成的 分享
Hi again, well, the laptop worked fine the last time and when I tried to power it up again, no longer come up, I've tested with another power supply, the charging lights indicate that it is charging, the jack connector is ok and receive power.
I don't know what else to do!!!
Thanks.
由完成的 分享
have you tried hooking up to another monitor . The video onboard may be the problem
由完成的 分享
Yes i have tried, only power light is on, no noise, no cooler, nothing......!!!!!
由完成的 分享
显示更多的1条评论
添加一条评论
Try increasing the brightness to max (keep pressing fn - f6 multiple times)
I had the same issue after updating the catalyst driver and it was blank until the screen brightness was at max, some driver bug.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luke Harris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 1,756
