跳转到主内容
The Polaroid One-Step 600 Camera takes and develops its own pictures. It features an automatic flash as well as a special lens for close up photos.
41 个问题 查看全部
Displaced spring in film release button?
A spring fell out from the left side of the film cartidge loading bay and I can figure out where it goes. It is a large u-shaped with a hook at each end. I am surmising it works to activate the release button to load film. If I had a schematic or exploded view of the camera, it might help to relocate it. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
i think the best way is to use the pictures of the teardwon for that camera: CLICK
it's surely not a repair guide (but if you look on the right side, there are 3 step-by-step guides) - but it's shows the most of the inside parts of the camera
这个答案有帮助吗?
得分 2
添加一条评论
Thanks, Marcus! I appreciate the help.
这个答案有帮助吗?
得分 0
添加一条评论
Hi
Did you ever resolve this issue. The same thing has happened to mine. I'm pretty sure it's the door latch spring.
Thanks
Stuart
这个答案有帮助吗?
得分 0
添加一条评论
Actually the U-shaped spring is the one that lets the door latch engage with the body. It is located at the right side of the Roller Assy looking from behind the camera. Observe the way it mounts on a functional camere, it´s tricky to describe in writing. The metal part it activates is visible on Step 9 of the dismantlich pictures.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 4,889
