跳转到主内容
The NutriBullet by the makers of Magic Bullet is a personal blender that is self-contained and simple to use. It includes an electric blender base with a number of attachments for the user and offers a healthy alternative to blending food by breaking down ingredients in their most nutritious states.
65 个问题 查看全部
I need to replace the swich which.
One of the activators has been forced while it was stuck. This resulted in the perforation of the top of the small plastic cylinder which holds a spring. As a result the lach is loose and does not play its role of actionating the switch. I need to buy the broken parts. Where can I find it ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Abdel add some images of what and where it is broken. Use this guide 在已经存在的问题里加入图片 to add those
完成的
添加一条评论
3个答案
已选择的解决方案
I dis-assembled as per insstruction, and found one of the two activators to be broken. Ordering and receiving can take some time, so in the interim, I cut the red and black wires and marred them together. The activators are wired in series so that works well until I get another.
这个答案有帮助吗?
得分 1
1条评论:
Called the service number. They will not sell or provide the springs or switch parts to repair. You can buy an entire base for $50. NO THANKS!!
完成的
添加一条评论
You may contact Nutribullet Customer Service Department at 855-346-8874 for assistance on using the product or warranty service. (Mon– Sun, 9am–8pm EST). You will be required to provide the barcode and serial number located underneath your Motor Base
这个答案有帮助吗?
得分 0
1条评论:
Jose Rivera, your response does not answer the question at all. ifixit is not about referring to the manufacturer but about how to fix it yourself. Ever tried to get the manufacturer to fix their appliances.?
完成的
添加一条评论
Doesn't look like you can buy replacement contact switches easily and online - I think wiring the switches in series will prolong the life of the blender without compromising safety.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abdel 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 37
总计 1,733
