跳转到主内容
这是一系列帮助修理洗衣机的指南和支持。
Kenmore elite he4 PF error code
Kenmore Elite HE4 showing PF error code
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
PF is power failure error meaning electricity has been interrupted to the machine.
An electrical interruption of any type can cause a PF error code.
Try this:
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
Reset the breaker box and make sure the machine is securely plunged in.
这个答案有帮助吗?
得分 1
1条评论:
I tried your helpful scenario, but unfortunately, I could not get short cycle to go on despite pressing the Start button. All I heard was a clicking noise while attempting that particular step & procedure. Any follow-up suggestions?
完成的
添加一条评论
My power went out and kenmore dryer displayed the PF code and dryer just kept beeping but nothing worked.Pushing buttons at random didn't work,But I just left it plugged in and beeping for 30 minutes to my surprise the beeping stopped I pushed the cancel button and then pushed jeans and pressed start after awhile it worked but to my surprise the beeping started again.I left it beeping for another 30 minutes and to my surprise again it stopped beeping I pressed cancel then normal dry and pressed start and it's been working since.Ive been told it needs a new board multiple times but yet the dryer is working with no problem to this day.Fornately I have another dryer so I could take the time to figure it out.Another problem I had in the past was the controls were all locked I held down the auto dry level and temperture buttons at the same time for 30 seconds then while still holding the two buttons I pressed the start button this cleared the locked buttons.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RobEarl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 4,064
