跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
121 个问题 查看全部
问题已关闭
Formating to Mac OS Extended
Should I format to Mac OS Extended (Journaled) or Mac OS Extended (Case-sensitive, Journaled)???
Update (09/05/2015)
It's Mac OS X 10.5.4???
Update (09/05/2015)
Thanks for helping me we all appreciate it!!!;~)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This gets into file names case. As an example the file MY.TXT, My.TxT, my.TXT, my.txt would be seen as different files and all could live within the same folder if you had selected Case-Sensitive.
If you had set for the default the file MY.TXT, My.TxT, my.TXT, my.txt could not exist in the same folder as the system would treat them all as the same file. If you had tried moving one of these into the folder the OS would ask you if you want to replace the other file.
The short of this is this use the default Mac OS Extended (Journaled) ;-)
这个答案有帮助吗?
得分 3
1条评论:
This was a continuation of this question and does not really stand alone as a independent question: Finding destination for installing operating disks..
Also some comments have been deleted that I made and do not show up in the history making the conversation hard to follow.
完成的
添加一条评论
最有帮助的答案
这个答案有帮助吗?
得分 3
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 112
