跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
问题已关闭
MacBook not booting up.
#1
A1181 Intel Core Duo Macbook 2006.
I have the above mentioned Macbook that was working fine. Over the weekend, I had it completely powered down and sitting on my bench. On Monday, I switched out the ram and hard drive, and hit the power button to boot it but it wouldn't respond. I've tried resetting the battery, etc... but the result is a dead Macbook. The 60 watt charger, while plugged in shows a very light green. It used to be really bright. Another thing I've tried is jumping the two pwr button pads near the fan on the logic board. Still won't turn on. If jumping the power button pads doesn't power it on, does that mean the logic board is dead? I have the MagSafe port on order to see if that will do the trick.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have noticed macs are very picky about the kind of ram they accept. Try putting the old ram back and see if it works. Jumping the power padsnot working does not necessarily mean a bad logic board.
这个答案有帮助吗?
得分 0
1条评论:
I put both the ram and hard drive back in and the same result. I think its either going to be the ac adapter, which before this happened, the green light was very bright, now it barely visible, or the magsafe port, which I've ordered a new one. The logic board I bought used off of eBay and had been working normally until after the weekend.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 159
