跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
118 个问题 查看全部
问题已关闭
Why display is so dim
When i turn on the display is so dim i can barely see the apple and fonts at all. When i tap brighten + button display gets bright for a second, then fades out to black again. I thought video card or logic board needs replacing. Dent in lower right corner indicates it was dropped at some point
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Move the screen back and forth to see if it is the inverter cables. If yes, replace the inverter cables. Nothing? Replace the inverter, here's how:
PowerBook G4 Aluminum 15" 1-1.5 GHz Display Inverter Replacement
这个答案有帮助吗?
得分 1
添加一条评论
To me this sounds like a back light issue it could ether be a loose connection or the back light itself has gone bad
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 127
