跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
问题已关闭
Upgrade CPU and HD
Hi,
I cannot update to the operating system yosemite because apple limited the possibility to update for iMACs from Mid 2007 . I have an iMac from early 2007 running with the operating system snow leopard 10.6.8. What CPU do you recommend with which specification?
1.) Question
Does this CPU works with my iMac:
http://www.amazon.de/Intel-Desktop-Proze...
2.) Question
Can you recommend a SSD Drive which I can use with this specific iMac to increase the speed of the iMac in combination with the right CPU
Below you can find the iMac Specification's:
Hardware-Overview:
Modellname: iMac
Modell-Identifizierung: iMac5,1
Prozessortyp: Intel Core 2 Duo
Prozessorgeschwindigkeit: 2,16 GHz
Anzahl der Prozessoren: 1
Gesamtzahl der Kerne: 2
L2-Cache: 4 MB
Speicher: 3 GB
Busgeschwindigkeit: 667 MHz
Boot-ROM-Version: IM51.0090.B09
SMC-Version (System): 1.9f4
Seriennummer (System): CK7050WRVUW
Hardware-UUID: 00000000-0000-1000-8000-0017F2CDEFCE
thanks in advance
Maria
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Pre-Installed MacOS: X 10.4.7 (8K1106) Maximum MacOS: X 10.7.5*
*This system can run the last version of OS X 10.7 "Lion" if upgraded to at least 2 GB of RAM. Although it has a 64-bit processor, it has a 32-bit EFI and is not capable of booting into 64-bit mode. It does not support "OpenCL" either. Please also note that OS X Lion is not capable of running Mac OS X apps originally written for the PowerPC processor as it does not support the "Rosetta" environment. This model cannot run versions of OS X newer than 10.7.5 "Lion."
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Hi,
I am sorry to be the bearer of bad news !
The CPU on this iMac is not upgradable.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 199
