Why can't I erase my hard drive or reformat MBR to GUID?
I'm getting ready to sell my MacBook Pro (Early 2011) and want to erase the hard drive and do a fresh install of Yosemite. I'm currently running 10.8.5 Mountain Lion. I bought the computer used, and do not have the original install disk (should have been Snow Leopard).
The hard drive is currently formatted as MBR, and disk utility won't allow me to access any erase options, create new partitions or select the GUID scheme. I'm also unable to access internet recovery mode when booting with cmd + option + R.
Any ideas on how to at least clear the disk? Even better if I can get it to GUID so that I can install Yosemite.
Thanks!
2条评论
I’m trying to format a used disc to start a fresh install of Sierra on a MacBook Pro I’m reviving.
When in the install Mac OS utility I get the error - Disk not formatted in GUID.
I exit to disk Utility and attempt to erase again in GUID - I get an error every time. It will erase in MBR but not GUID.
Any thoughts?
由 MakeItSimple 完成的
What are you using? You need to be formatting the drive under a bootable macOS drive. If you are using anything else it won't prep the drive properly.
由 DanJ 完成的
