跳转到主内容
The Lenovo G570 is a 15-inch laptop announced in January 2011.
23 个问题 查看全部
Why is my screen black?
So i was on my laptop and I turned him off.The next day when I turned him on the screen was black,like it is on and i loged in but after that my screen was black and only thing i can see is my mouse moving......help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Sounds like it is not loading your system files. What OS are you using?
完成的
添加一条评论
2个答案
已选择的解决方案
Did you try to reboot him if that doesn't work try removing the battery and then unplugging it then hold down the power button for 60 seconds then put your battery back in and plug him in and start him up . Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
hold a flash light to the screen wile on if you can see it then but only ware the light is the back light is bad or ballest for the light is bad. also try the function key to set it on a ex monitor it may be on that setting now.
hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Emily Styles 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 1,455
