跳转到主内容
Blank screen, external monitor works
Just yesterday, the screen suddenly went blank. Connected to external monitor, evrything seems normal. Today morning, when I put it on, screen was magically working again. Then after 2-3 minutes it went blank again. The logic board on this macbook was replaced two weeks ago (due to some liquid spill). Is it possible that some cable is loose inside? Even though, It's less than a year old, I can't take it apple because the liquid spill voided the warranty. Please suggest what to do. Thanks...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
Who did the repair?
完成的
Switched the macbook ON yesterday after a long time, and magically the screen works now. No blank screen. Don't know what was wrong before.
完成的
添加一条评论
3个答案
The problem resolved itself without doing anything.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem after replacing a damaged retina display on my 13" MacBook Pro. I have followed other troubleshooting recommendations and gotten nowhere. My external monitor is the only way I can use my computer.
这个答案有帮助吗?
得分 0
2条评论:
Yesterday, the screen went blank again. It seems like there may be a loose connection somewhere, but I can't find where. May have to take it to the apple store again and pay $$$.
完成的
I took it to a local mac repair guy, and he said the video cable was bad. He replaced it, and it's working again. Thank god, it was not an expensive repair.
完成的
添加一条评论
Hey, I've a question. Does A1502 MBP work without its own display ? I would like to remove my non-properly working screen completely and use the MBP with an external monitor.
I'm asking this question under this thread because I think blank screen here should mean no screen and therefore it should work with an external monitor after I remove the OEM screen. Not sure though
这个答案有帮助吗?
得分 0
2条评论:
Ive seem a macbook air were the entire display assembly was ripped off of the computer, but the rest of the computer worked perfectly fine with an external monitor or projector. So yes it should still work.
完成的
Yes, my A1502 is working like that.
完成的
添加一条评论
添加你的答案
Janeisha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,594
