跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
369 个问题 查看全部
Can I fix my water damaged new 3ds?
I was drinking water and a few drops fell on the circle pad, screen, and A,B,X, and Y buttons. I was playing Super Smash Bros on it during this time. I wiped it off with my shirt. It was fine for about twenty seconds, but started flickering. I turned it off and back on and the top screen was black. The bottom screen was flickering, so I turned it off. I covered it with rice and put in a Ziplock bag. I found out later that you aren't supposed to turn it on. What should I do? I don't want to send it to Nintendo. If I have to, can someone suggest a cheap place to fix it at? Thanks.
P.S. It is the New Nintendo 3ds XL.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
My new nintendo 3ds xl fell down on the sea shore and some water went into it and it was on the standby mode,when i tried to charged it,it worked when i tried to switch it on but it won't turn on.
What do I do?
完成的
My Nintendo 3ds xl got water on its screen and started flickering and now when I turn it on it shows the normal screen for about 2 seconds then goes black and says an error has occurred, how can I fix it
完成的
添加一条评论
4个答案
已选择的解决方案
Clean ever connection with a soft toothbrush. As well clean the logic board use a 99% isopropal alcohol for all cleaning. now is the time to start drying out the ds. Set the screens in a desiccant or silica gel leave it in for several day moving it from time to time to get the max effect from the desiccant . use a blow dryer on a low heat setting to dry the rest of the ds. Only use a hair dryer once you have cleaned the ds completely with the alcohol. Do not attempt to dry the ds if its still wet with water with the blow dryer as this only spreds the water. Replace the battery with a new one consider the old ones done. Clean again with isopropal alcohol let dry and when you think everything is clean and dry reassemble the ds (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the ds its time to power it on. Hold your breath and hope for the best
这个答案有帮助吗?
得分 7
2条评论:
Can u pleaz send vedio
完成的
I was playing with my 3ds in and the water like a dumb ass and do I put the 3ds in rice
完成的
添加一条评论
I put my brand new Pikachu 2DS XL in a backpack, and I put a can of coke in the same bag. When I got to my destination I have found out that my DS was soaked. It worked when I turned it on the second time last night.
Now the next day both of the screens are black. I am not letting my mum find out because I only got it a week ago. What should I do?
这个答案有帮助吗?
得分 0
添加一条评论
I use 3ds in the bathroom and the water or heat got out of it but doesn’t want turn off or do anything but water is coming out and what do I use like rice and tearing it part is hard for me to without no one knowing I did it
这个答案有帮助吗?
得分 0
添加一条评论
Put in rice and a bag
这个答案有帮助吗?
得分 -1
6条评论:
RIce is a food not a tool
完成的
Old wives tale, totally ineffective.
完成的
That didn't work
完成的
Plz help, I spilt so much water on my 3ds xl that the water was coming out of it. I have no clue what to do. I'm crying so hard Becuase I don't know what to do and I don't want it to die.
完成的
same i spilt a little bit of hot co co on the bottom screen and in quickly cleaned it off i then dabed a little bit of water onto a paper towel and it still worked then i went to school and i checked to see if it was ok after lunch and i turned it on i heard the sound indicating it turned on but both screens were black pls help
完成的
显示更多的1条评论
添加一条评论
添加你的答案
epic377 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 20
总计 12,618
