跳转到主内容
The Asus X53E is a 15.6-inch Windows laptop released by Asus in 2011.
How to replace the fan inside the laptop
the fan in my asus x53e laptop has stopped working awhile ago. ive noticed it near the the end of the semester where the left side of my laptop became really hot and then checked to see if there was air flow on the side. it still boots up and works on different battery options but im scared that putting it on high performance will do permanent damage. is there a guide to replace the fan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your first mistake was using a laptop with a fan failure. STOP USING THE LAPTOP UNTIL YOU REPLACE THE FAN, OR YOU WILL SHORTEN IT'S LIFE OR KILL IT!!!
You're going to need to tear the whole laptop down, down to the motherboard. You do not need to remove the screen, but this will take hours to fix most likely. For yours, the fan can be found here (and many other places). The P/N for the fan is ksb06105hb. You will find metal and plastic versions, but you really want the metal version for this laptop. This model's cooling is like every other laptop: compromised. The metal fan will help reduce the severity of the issue these are known for.
这个答案有帮助吗?
得分 3
2条评论:
The guide that you link to shows as "Forbidden Access".
完成的
It just now showed "Forbidden Access" for me too.
完成的
添加一条评论
添加你的答案
david ha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,196
