跳转到主内容
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76 个问题 查看全部
问题已关闭
Replace HDD to SSD
Dear Friends
Greetings and well wishes with a good health...
Need a help please!
My Mac mini HDD is slowing down. I wish to replace to SSD, before doing do so, I wish to confirm and verify that my Mac mini can support any brand of the SSD.
MAC MIni Mid 2011
Processor 2.3 GHz Intel Core i5
Memory 8 GB 1333 MHz DDR3
Graphics Intel HD Graphics 3000 512 MB
Serial Number C07G2LGRDJD0
Software OS X 10.9.5 (13F1096)
My choice of SSD to be purchased
SanDisk Ultra® II Solid State Drives (SSD)
Selected: 240GB
Specifications
Dimensions: 2.75 x 3.96 x 0.28 in. (69.85mm x 100.5mm x 7.0 mm)
Shock: Resistant up to 1500G
Vibration: Resistant 5 gRMS, 10-2000 HZ / 4.9 gRMS, 7-800 HZ)
Temperature: 32ºF to 158ºF (0ºC to 70 ºC)
Interface: SATA Revision 3.0 (6 Gb/s)
Endurance: MTBF: 1.75 million hours**
Warranty**: United States: 3-year limited warranty. All other regions: 3-year warranty
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Dear All Friends
Greetings and best wishes!
My heartiest thanks for your kind support and cooperation. Sincerely I appreciate very much for your quality time contribution. I am going to fix my SSD soon, and looking forwards for the speed.
完成的
添加一条评论
3个答案
已选择的解决方案
Yes, a 2.5" SSD will work here (any manufactures).
But before you make the jump how about doing some house cleaning of your HD to regain its speed. Over time old cache & log files build slowing down the system, give this app a try: Disk Doctor from the Apps Store.
Make a good backup of all of your stuff then see if you can free up 1/4 - 1/3 of your drive. The last two steps require a bootable external drive (a USB thumb drive will work). Bootup under the thumb drive and run Disk Utility repair the Permissions & Disk. Then you'll need to defrag the drive, I like this app: Drive Genius Pro there are others. After doing all of this your drive will have all of the zip it once had!
You'll still want do to this even if you do decide to go with a SSD as you'll want to transfer your apps and data to your SSD so having it clean & healthy will improve things.
You may also want to think about swapping out your optical drive for the SSD. Here's the IFIXIT guide to do that and the needed holder: Installing Mac Mini Mid 2010 Dual Hard Drive. That way you hang onto the deep storage of your HD and gain the speed of the SSD as well.
这个答案有帮助吗?
得分 3
添加一条评论
Greetings,
If you can replace the hdd for a hybrid you must be able to use a scandisk ssd ... that's what I think.
See [关联产品丢失或禁用: IF107-122-2]
[关联产品丢失或禁用: IF107-098-3]
这个答案有帮助吗?
得分 1
1条评论:
What is this BS on using "scandisk ssd" which is Microsoft software on a Mac disk? Since when does an Apple require Microsoft to do anything?
完成的
添加一条评论
It's best using an SSD. Hybriddrives are slower than an SSD, but they have more capacity than a normal SSD, and it's better for the price. SSD's is more likely to be more stable, and more robust if u drop it, or shake it.
The Hybrid's is like a HDD, but with an SSD built into it. Hybrid's, and HDD both have movement built into, and theres a small pin (the arm) there are writing on the spinning discs, and if they get out of control, if u drop it, or shake it, it will scratch the disc, and maybe get stuck.
An SSD has no movement at all. And after it's a mac mini, i think u are going to move around with it.
Good luck with it, and happy repairing.
Greetings, Rasmus
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 1,091
