跳转到主内容
加入维修社区 - 创建账户
Released November 2013. 32 GB of Flash Memory. 8GB of RAM. Quad-Core Processor. Identified by model number EGQ307. 7.58 x 4.60 x 0.45 inches. 1080 x 600. 4.5 hours battery life.
Why isn't my camera working when the application opens?
The application is opening but the screen in black and any photo I take is coming out black.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Issues with your camera can be either software or hardware related. There might be a problem with your camera app, in which case, you should try reinstalling your camera application. Always make sure your Android OS is up to date. As an extreme solution, you can attempt a factory reset; however, this will wipe your device. Make sure to back up the stuff you want save!
If none of the above software solutions work, your camera might be damaged and need to be replaced. Sometimes the connecting ribbon might have come lose, and you only need to reattach it. Use the camera replacement guide, for information on how to replace or repair your tablet's camera.
Ematic EGQ307 Front Facing Camera Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ashley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 230
