no water or steam coming out of steam wand, not clogged..
When i turn on the machine and nob, the button for making espresso works but there is no water or steam coming from the steam wand, i did check to make sure water flowed through it when i took the wand off.. that was fine.
2条评论
This didn't wrk for me...i even replaced the pump...still not enough water pressure, water slowly drips out of steam wand, and espresso area. any other ideas?
由 Emily 完成的
You probably have a clog then, and since it's effecting both the brew head and the steam valve you may need to open up the boiler to clear it. I would try a good descaling first though.
由 Henry H 完成的
