跳转到主内容
加入维修社区 - 创建账户
Xbox Wireless Controller 7MN-0001 由微软公司制造,是 Xbox 游戏机最常用的控制器,也可以用于 PC。
The X button Doesn't Work.
The X button (not the guide button) on my controller does not work; however, every other button does work. Which motherboard do I need to replace to fix this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
7条评论
Hello, Has anyone gotten any answers on this matter? As of now this is part of an issue I am having with my controller. Should I call XBox for assistance?
由完成的
same thing has happened to me aswel… i was not bothered to much i just rerouted X to the bottom back paddle.. now the kids have broken the shells so gonna re do all the parts.. I really want to know aswell if the X button is a hardware or software problem
由完成的
It also happened with my controller from the xbox one s. Got it connected to the iPad Air and played Genshin impact. Suddenly the X button stoppend working. Connected it to my xbox and it si somehow overly sensitiv. instead of moving one tile it moves two. Updating the controller firmware did not do anything. Problem is the same. I can not point out if it is a hardware or a software problem. I only know firmware update does not cure the controller.
由完成的
mine is the Model 1708 so it seems to be a general issue
由完成的
the same thing happened to me but im still trying to figure it out
由完成的
显示更多的2条评论
添加一条评论
2个答案
最有帮助的答案
Have you tried cleaning the membrane (the rubber thingy with the buttons on it) and the motherboard using a cotton swab and isopropyl alcohol?
这个答案有帮助吗?
得分 1
添加一条评论
Take a screwdriver and press the button as much as you can i did it and it worked hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Turner747 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 15
总计 13,189
