跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
Cameras not working after screen replacement
Replaced a cracked iPhone screen everything works fine except the cameras, I open the camera app and it just stays black on both cameras it does this on other camera apps, but the loudspeaker and proximity sensor work fine, the inside of the phone has a sort of whitish powder that reminds me of corrosion, the customer said the phone was a networking problem before hand, what do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you try doing a soft reset on it?
Try doing a soft reset on it first then see if the cameras come up working!
If this does not work try new cameras front and back, and if that is not working then it is water damage problem if there's any kind of corrosion around the plug-ins most likely that is your issue
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 121
