跳转到主内容
The Motorola E815 is a flip phone camera phone by Motorola.
3 个问题 查看全部
问题已关闭
Power Connection broken? How do I fix it?
My phone refuses to charge. Charger is fine, battery is fine. It went to the repair company and whatever bit needs fixing is the only one the warranty won't cover.
I've got a tear down guide from mark.cdmaforums.com/Files/e815guide.pdf
but it doesn't really say anything about the part I have the problem with. Is it the charging connector? Can it be fixed or does it have to be replaced? And could anyone tell me how to do it? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
does you phone react i any way when you connect the charger or does it "ignore" the charger ?
if you google around - you will find many postings about motorola phones and charging issues - including the E815
the old charging system was a pain. but if the contacts are not bent or dirty (on both sides) - it's not easy to tell anything without measuring inside the phone
这个答案有帮助吗?
得分 1
1条评论:
The phone basically ignores the charger, it used to if you jiggled it a certain way, but now nothing. Connectors on both sides (phone & charger) seem fine, not dirty or bent. I know you can purchase the charging connector, but I don't know if it's separate from the motherboard or not. If it's attached I'm thinking it'd be easier to replace the whole motherboard. I know this version had a lot of charging issues and I have since replaced the phone, but it had a lot of features that I liked, and I'd like to bring it back to working order if I could. I suppose another possibility would be to create a battery charger for it and just remove it every time it needs charging. What would work do you think?
完成的
添加一条评论
You would need to solder a chargwer port or resolder yours
it requires board level tough
这个答案有帮助吗?
得分 -1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,617
