跳转到主内容
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
60 个问题 查看全部
Samsung gear watch charger is not charging my watch.
My samsung gear watch will not take a charge, don't know wether it's the charger or the watch. I don't think it is the watch because it was working fine when it was charged. How much are the charges?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
the contacts on the watch are scraped off. can I order the re64 board
完成的
添加一条评论
3个答案
已选择的解决方案
Same issue...my charging contacts on the back of the watch were worn away. From another thread I learned about the Circuit Writer, a pen that dispenses conducting ink. A drop on each contact and my watch charged again, and the pen was only about $12. Hope this helps!
这个答案有帮助吗?
得分 4
3条评论:
What store did you get the Circuit Writer from?
完成的
Apologies for not responding sooner! I picked it up from Ama zon, was about $12.
I've used it twice more since I posted this, and my watch is still charging.
完成的
A follow-up: It's 8 months since I first used the Circuit Writer on my fading contacts, and have used it 5 times, and finally can't get it to charge any more -- I believe there just isn't enough of the original contact left for this hack to work.
So I ordered a brand new (old stock) Galaxy Gear 2 to replace my old faithful. $120 including shipping from Ebay, and it will be here tomorrow.
It was well worth extended the life of my watch by 8 months for $12, and still recommend you try the Circuit Writer trick! Thanks for following along.
完成的
添加一条评论
Where can I send my samsung galaxy gear watch for repair? It will know longer take a charge.
这个答案有帮助吗?
得分 2
添加一条评论
the outer case of my gear 2 neo got broken. where can I find a replacement?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wayne dozier 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 13,378
