跳转到主内容
The Beats Pill is a small, portable Bluetooth speaker from the Beats by Dre line of products produced by Beats Electronics LLC. It features direct audio and Bluetooth connectivity as well as an internal microphone to conduct phone calls. This device is fairly capable of being repaired due to its intuitive construction.
32 个问题 查看全部
Small dent on mesh metal of beats pill 2.0
how can i remove the mesh metal of the speaker to get to the back of it so i can smoothen out the dent
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
8个答案
最有帮助的答案
I have a 2.0 and yes it will slide off, just give it a slight hard pull and it should slide right off.
这个答案有帮助吗?
得分 3
1条评论:
How do you put it together will it just clip in? Or does glue need to be used
完成的
添加一条评论
Follow this guide to see how it’s opened:
Beats Pill 1.0 Motherboard Replacement
这个答案有帮助吗?
得分 2
添加一条评论
they slide off the side pretty easy. Just pull really hard and it should come off
这个答案有帮助吗?
得分 1
6条评论:
it slides off at the sides just needed to clear that up
完成的
do i just pull it off its a pill 2.0 not a 1.0 if theres any difference
完成的
How? i cant do it...
完成的
i have the 2.0 and it will not slide off please help
完成的
It won't work for me either not sure what to do now
完成的
显示更多的1条评论
添加一条评论
Dissasemble per all of the vids out there and then gently lift the corners of each speaker grill that are closest to the beats "b" in the center, you may have to go back and forth between top and bottom corners but then they should just lift off or slide out
这个答案有帮助吗?
得分 0
添加一条评论
You could use a knife and slide it on the top and pop it off or slide it and to fix the dent you could use a flat screwdriver and push the dent some people use also other equipments. So feel free to try them all!
这个答案有帮助吗?
得分 0
添加一条评论
The mesh is somewhat hard. You will have to obviously disassemble the mesh out of the speaker body and then use a rounded tool ( like the handle of a screwdriver ) to push the bump out ( put the screwdriver in a table, place the mesh on top and the n push gently). That worked like a charm !
这个答案有帮助吗?
得分 0
添加一条评论
How do I fix the beats pill plus grill and the grill keeps coming out and I need help to force it in back any tools
这个答案有帮助吗?
得分 0
添加一条评论
Take off the mash grill and find a plastic hammer and light hit it times where the dents are in the mash grill you wanna tap it and wear gloves and wear eye protection goggles
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gavin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 21
总计 14,673
