跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
问题已关闭
Why is touch not working on samsung galaxy s4 after I repair?
I use loca to put in a new screen on my s4 and after the touch was working on the screen normally then suddely it doent work anymore. Can anyone tell me why none of my button working right now. Back button and menu button . Help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
When you did the loca on the glass, did you remove the LCD and apply it to the glass, or did you leave the LCD in the frame? If you left it in the frame during the glass replacement, did you tape off all the areas where the loca is not supposed to go(top and bottom of LCD, over the top of the power button area, over the top of the LCD connector area)? If it was working after the replacement, and now its not, then it sounds like the loca has leaked into areas of the phone where it shouldn't. Try removing the phones rear housing and check for excess loca, especially on the LCD connector. If you find glue, disconnect everything and clean it with isopropyl(90% or better). The menu buttons may not be working for the same reason. This could all be due to damage from removing the glass as well. It is very easy to damage the LCD and the menu button flex during the process.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 603
