跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Help! My phone is glitchy and ghost clicking everywhere!
So I dropped my phone and ever since then, it is super unresponsive. Every time I click, a ton of random apps open and close and it makes my phone nearly impossible to use. I've tried resetting it. I'm going to try a factory restore but if that doesn't work, is there anything I can do to fix it? I'm a broke college student so I only want to take it in for a repair as a last resort. How much do you think it would cost if I did have to take it in?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Use this iFixit guide to disconnect then reseat the display cables.
If the above does not help, then you need a new screen assembly.
That same guide has links to the needed parts and tools. iFixit sell excellent quality screens in a kit complete with the right tools that allow you to attempt the repair yourself. Otherwise, depending on the quality of the parts used and price policy of the repair shop, replacing the screen should cost you something between $65 up to $109+tax if you go to an Apple Store.
Don't buy a cheap screen from eBay or Amazon. This will end up costing you more that buying a good quality part from reputed sellers that stand behind their product with a solid warranty. If you receive a defective part, and have to repeat the process a couple of times, that's double the risk of damaging something in your phone since every time you disassemble your iPhone (or have it disassembled), you risk damaging something - may be permanently. Take if from someone who does this for a living.
Good luck!
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much!
完成的
添加一条评论
yo um kys thank you have a good day
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Doc Green 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 5,725
