vertical dead spot right side of display
I have an iPhone 4S with a dead spot on right side of entire screen, before everybody suggests bad digitizer, I just want to say I tried a few different screens with the same problem I even removed the logic board and put it in a working phone same problem. The problem is at the logic board level and I wanted to see if anybody knows which component is blown so I can replace it, bacause looking under a microscope there isnt anything obvious.
2条评论
Have you used a meter to check the caps around the touch screen controller? There where I would start to after all the checks you already did.
由 oldturkey03 完成的
Thanks , That is a good place to start!
由 Masterminds iRepairs 完成的
