跳转到主内容
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
74 个问题 查看全部
Any way to replace the smooth plastic bezel?
I dropped my lg g4 today and it held up pretty well, it was not from a high height, as I was getting out of my car, and did land on the back but the plastic bezel was dented in two places on one side of the phone. I could just get used to this cosmetic damage and still use the phone, but I was wondering if there was any way to remove the plastic bezel and then replace it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
添加一条评论
1个答案
已选择的解决方案
Hi Everyone, The sides of the frame are attached to the Glass and LCD Assembly . It is Possible to remove your Display Assembly (Glass,Digitizer,and LCD) from it for replacement but you are able to find the Full Display Assembly with the Frame for about 70 - 80 bucks online. The Frame alone is much harder to find and you run the risk of damaging your display in the removal process. You will thank me by just getting the Full Display Assembly Replaced.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
iantagtow 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 10
总计 2,961
