跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
I can't reject the disk
My Fifa 15 disk stuck inside my ps4 I can't get it out, I can't even play it. PLEASE HELP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
There is a manual eject screw that you can use to eject the disc. Here is a guide for that:
https://support.us.playstation.com/app/a...
If your disc is stuck inside you'll need to repair the optical drive as well.
I hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
Requirements:
Your PS4 Unit
A Well Lit Room or a flashlight/Headlight
And A Slender Phillips Head Screwdriver
Note: There's 3 Types Of PS4 units, I will go though one
-_-_-_-_-_-_-_-_-_-_--_-_-_-_-_-_-_-_-_-
1) The Sony PS4 (CUH-1000 + 1110 Series)
Step 1: Make Sure EVERY connected cables from the back and front of the PS4, Includes Power (obviously)
Step 2: You May have to remove 1 or 2 Security Torx bits (Probably a security T5 - T6. Maybe different) which is located behind the ps4, between the 2 Cooling fan intake, under 2 stickers saying "By Removing This Tag, You Will Take Full Responsibility Of Modding, And Voiding The Warranty". Then after unscrewing them, remove the HDD Bay Cover by sliding left of the cover, which removing it.
Step 3) You will see 2 vents lining the outer left edge. Locate the first single slit which is the slot that is not grouped with the others, shine a light in the vents and you will see a Phillips like head, turn left until it releases the stuck disk, I will do the others.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jmonneus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 167
