跳转到主内容
加入维修社区 - 创建账户
三星热门 7 英寸 Galaxy Tab 平板系列的第四代产品。
My Samsung Galaxy Tab 4's Screen Is Not Working..
My Tablet is on and the screen is just black with with blurry lines but I haven't been able to use the tablet for almost a year and it was new.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
It didn't work :( the screen lights up but there's nothing on the screen except the white lines and black everywhere else.
完成的
same problem comes in my samsung tab..so what you do??
完成的
If you can open and remove the back cover of the tablet (or ask a tech guy to open it), check the two cable connectors from the screen to the motherboard. One is the LCD and the other is the digitizer. I don't know which is which because I have seen them on tablets that were damages and disassembled. Maybe one of them is not well seated, so carefully press them down, and power the tablet on to check. You can do this without the back cover on and the battery reconnected.
完成的
添加一条评论
2个答案
已选择的解决方案
You can try a hard reset this will take you back to new all your data and apps will be lost but at least you should have a working tablet
http://www.technipages.com/galaxy-tab-4-...
This is a walk through on haw to do it. Good Luck
这个答案有帮助吗?
得分 2
1条评论:
Screen is not working touch is not working anymore how can I reset it and if I try to reset it with on off button it sucks it can't reset or switch off my tab is galaxy tab a9 plus
完成的
添加一条评论
If it’s almost a year, and it was new, it will be covered under a warrenty
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessica Goode 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 5,564
