跳转到主内容
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180 个问题 查看全部
Big bold vertical white lines after screen replacement
Hey I have a G3 and I recently replaced the screen with the entire frame.. After installing it worked fine. But after five minutes the screen started to show me a bunch of thick white line going from one end to another of the screen. Would you guys have any idea why this is happening ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
最有帮助的答案
Bad connection to the daughter board on the bottom of the assembly
这个答案有帮助吗?
得分 2
1条评论:
I have the same problem after I dropped the phone, hopefully I just have to check the connections on mine. Thank you very much for this answer, you probably saved me from repurchasing the screen for nothing!
完成的
添加一条评论
添加你的答案
blockboy21814 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 798
