跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
itunes error 48 , stuck in recovery mode
i would like to know how to fix the itunes error 48 because i am stuck in recovery mode until restore
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 98
63条评论
help me ! how to fix error 48.
完成的
hi.. did you find solution with the error 48? pls let me know
完成的
can u solved this problem ? because i have same problem with this.
完成的
guys i found the answer with error 48.. check it solvusoft.com and emal me if it works for you^^ my email is rosebear.laygo@gmail.com
完成的
help me plz, error 48 in recovery iphone 4s. teccelp@gmail.com
完成的
显示更多的58条评论
添加一条评论
7个答案
已选择的解决方案
Here's how to fix error 48
1. Update your iTunes software
2. Restart your iPhone Device and Computer
Turn off your Device and your Computer. Then Turn them ON again. It will fix this iTunes Error 48 problems.
3. Unplug any extra USB Devices
4. Restore your iPhone Device without SIM Card
Remove the SIM Card
Restart the Device
Now, connect to iTunes
Start the ‘Restore‘ process
5. Clear your iPhone Browser Cookies, Cache, and History
Go to the Settings
Click on the Safari browser
Select the ‘Clear Website Data.’ option there
6. Do a Factory Reset of your iPhone Device
Go to the settings
Click on the ‘General‘ option
Now, click on “Reset & Approve” option there
By doing a factory reset of your iPhone can also fix this iPhone restore Error 48 problems.
7. Reset your iPhone Device
One of the best methods to solve this Error Code 48 problem is to reset your device. It will make many changes to your device. & also, make it better too. I know its most annoying & frustrating task, but it will help you.
Press & hold the Home & Sleep button both (about 15 sec.)
Reboot it
8. Run the Recovery Mode for your iPhone Device
Turn off your iPhone
Open iTunes & then
Connect your device to your PC by USB cable
Press & hold Home + sleep/wake button for some seconds
Now, release the power button
You will get ‘Connect to iTunes Screen.’
Now, your iPhone will be detected in ‘Recovery Mode.’
Backup & Restore the Data
这个答案有帮助吗?
得分 4
添加一条评论
Hey Jake, this error usually happens when your ipsw is corrupted. I'd recommend you to download the firmware you want to update to. Then on iTunes while you're clikcing the restore button click the option key if you're on a Mac or the alt key if you're on pc and then choose the ipsw you downloaded and it should restore to that iOS: Also try this and this.
-Let me know how it goes.
这个答案有帮助吗?
得分 3
4条评论:
Even I downloaded ipsw many times, it's still occur the same error.
完成的
完成的
Hold the shift key on a pc.
完成的
What on earth is one to do when you've already ERASED the iphone/factory reset it.....and you're trying to recover, and NOW you're getting the Error 48 message??? I get almost completely thru the Recovery process, then when it gets to the firmware stage, I stopped cold with the 48 error. But with an already erased iPhone that obviously cannot get to my Home Screen, or go online (all it can do is hook up to iTunes, via another
computer), I do not know a method by which I would be able to access that firmware.....even if it is the problem behind all this.
There must be a way though, right...? :-)
完成的
添加一条评论
Over the years we’ve had a few SmartPhone Recovery PRO customers contact us asking how to fix an iPhone stuck in recovery mode. As it appears to be a common problem (even among some of us here in the office), we thought we’d share a few methods of how to kick an iPhone out of recovery mode.
An iPhone can sometimes get stuck in recovery mode if:
You intentionally activated recovery mode to solve a problem
You’re trying to jailbreak your iPhone and it all went terribly wrong
Like many of us – you were simply trying to update to the latest iOS software
Here are our suggested methods of recovery if your iPhone is stuck in recovery mode:
Option A – Tiny Umbrella
Option B – iTunes Restore
Typically if your iPhone is stuck in recovery mode, this automatically means you have to kiss goodbye your current iPhone data and settings. The general method of recovery for an iPhone stuck in recovery mode is an iTunes restore – great if you have recently performed an iTunes backup, tragic if you have not. If your last iTunes backup was a while ago, you risk losing any data added to your device since your last iTunes backup. However, there is now a software that claims to get your iPhone out of recovery mode, without causing data loss (this method has also been known to work on a pesky iPad or iPod Touch stuck in recovery mode). Just follow the steps below to kick your device out of recovery mode. If you’d rather stick to the traditional iTunes method of recovery, scroll down to Option B and follow the prompts to recover any data obtained after your last iTunes backup.
这个答案有帮助吗?
得分 2
1条评论:
how to fixd apple iphone 5s error 50
完成的
添加一条评论
100% fix this problem
heat the baseband ic at 350° for 15 seconds
这个答案有帮助吗?
得分 2
添加一条评论
ERROR 48 SOLVED!!!!!
Hi,
Updating my 4S to IOS 8.4 was not succesful. Recovery using Itunes gave an Error 48.
Only fools do things over and over again and expect a different outcome.
So there I was being a fool trying recovery after recovery as suddenly I had an idee.
In my opinion there are 3 main factors: the hardware, the software and the test to make sure everything is working properly.
Hardware suddenly broke during update? I don't think so.
Software not OK? Not likely as the same software is already on millions devices.
Test not OK? Probably!
As I noticed being a fool, the Iphone was preparing, installing and testing and just before finishing gave Error 48. So the next time I tried, after the installation was finished and testing was about to end, I simply pulled the connection cord with my macbook and thus with Itunes. Now the testsoftware in Itunes, couldn't tell my Iphone he was not OK and he started just like that and is working properly ever since.
In this case, the patient was sic just because the doctor told him he was.
Maybe, there is something somewhere not 100% Ok, but if I can make calls, read mail, surf the net, use whatever app I tried so far, it is just a perfect working Iphone to me.
这个答案有帮助吗?
得分 0
9条评论:
May I ask you to be more specific? This is the first answer I see to this problem but I don't understand. You restored via your macbook I guess? And you unplogged while restoring but in which step??
完成的
I restored using Itunes on my macbook.
Put Iphone in recovery mode. Connect to Itunes, follow steps to restore, device will get the software, unpack it, install it, restore firmware and than start testing. The progression bar will jump to the end and stay there for a while and then will give Error 48. Just unplug the device before the error appears.
Before I did this I tried everything from dfu mode to uninstalling and reinstalling Itunes. Hard to give a detailled description and as you will understand, I will not try if I can do it again on my Iphone. If it ain't broke, don't fix it
完成的
I'm glad it worked for you but it didn't for me. After restoring the firmware that's it for me. No testing or anything. I tried unplogging in many different times but it just doesn't work. Thanks anyway.
完成的
My phone progress bar is stuck at the end after unplugging the cord.
完成的
完成的
显示更多的4条评论
添加一条评论
DEBES REEMPLSAR EL IC POWER BASEBAND EL U18_RF
这个答案有帮助吗?
得分 0
3条评论:
solucion despues de leer y hacer una investigacion puesto q al restaurar con mi mac y usando purple restore el error q me arrojaba era al descargar los baseband... con itunes solo error 48 no te dice de q pero purple restore si... la solucion despues de leer es reemplazar el chip IC POWER BASEBAND ... saludos chao...
完成的
reemplazar en chip u18_rf
完成的
完成的
添加一条评论
If you keep failing in iTunes, you can try to flash your device with itunes alternatives.
You can use 3uTools
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jake lopter 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 33
总计 86,293
