Why my calculator is not charging?
When I plugged in the charger, it shows greenlight but still low battery even though I charge it overnight
I read on another site that if you unscrew the battery compartment, unwrinkle the cords, it will charge better. I didn't think that would work, but strangely enough, it is charging and actually working. Hope this helps.
这个答案有帮助吗?
It worked! thank you :)
Reset your calculator: If you turn to the back of your calculator in the mid-left you will see a small button that says reset.
If this method doesn't work for you then you might have some other problem.
这个答案有帮助吗?
If your graphing calculator isn't charging and it doesn't take 4 AAA batteries then it works on a block battery that you have to unscrew the 2 screws and unplug it for 10 seconds, plug it back in and tighten the 2 screws and charge it and it will function normally.
这个答案有帮助吗?
Your calculator battery may be reduced in lifespan and it could also be your charging port. You can buy charging ports for TIs and other brand calculator online.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 71,887
9条评论
由 dirkathena 完成的
how do you open the battery compartment though? mine wont open
由 Sarah Durbin 完成的
Sarah Durbin you checked this guide?
由 oldturkey03 完成的
This worked for one of my students. Thanks for the suggestion!
由 Kathy Hansen 完成的
but what if you have the one that is color and doesn't run on batteries
由 Ian Greenwood 完成的
显示更多的4条评论
