跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
How to fix ethernet plug recognition?
Hello,
When I plug an ethernet wire (plugged to a switch with a printer, wifi access point, etc) the network is not recognized. On the Network configuration, the Ethernet dot is still red. And on the switch, the lignt in front of the Quad Core iMac line is off... I used several wires, the several ports of the switch, but nothing...
Under Mac OS X 10.6.4 I see the en0 device, under Windows 7, I see the Broadcom card (but still unconnected) and everything seems alright... Except that when I plug it does nothing...
Any idea ?
Thanks in advance,
And sorry for my poor english.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
either the nic on your mac is bad or your switch is bad.
if the port that your printer is plugged into is working try plugging your mac into that port.
If it still does not work and your sure your cable is good then your nic is faulty.
这个答案有帮助吗?
得分 1
3条评论:
what's a nic?
完成的
Hi Richard--network interface card--a windows device primarily. Ralph
完成的
Well, it seems that the nic is dead... Well, what now... Can I change it myself, or is it included on the motherboard ?
完成的
添加一条评论
最有帮助的答案
If this is indeed a Late 2009 machine, it's still covered under warranty and Apple will repair it for free.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the tip...
完成的
添加一条评论
添加你的答案
Matthias Lamoureux 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,236
