跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
I am getting code (-18)
I replaced the screen with another LCD Digitizer on the I phone 6 plus. Kept giving error code 53 and hanging in the middle of the download. I read on forums to put original screen back on and then try to update. Now I am receiving code -18. There is no help for the minus (-18) on any help from Apple or google that I can find.
I have no firewalls
I have updated my computer
I have the correct data cable
I have cleared all cache/cookies
I have uninstalled and reinstalled I tunes
I have the latest updates on my computer and I tunes
I have done the same process on 2 different computers and come up with the same -18 code.
I have went back through the Iphone 6 plus and made sure all connections are secure
I have pressed the power but to release the power with the battery disconnected on each occasion
I am at a loss on what to do, I need some help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Home button / home button cable are original and connected when doing the restore? Anything torn/broken?
Did you screw back the metal shield over the screen connectors and mixed up the screws in the process?
完成的
I have had others that have broke the flex cable by cracking and smashing it and a different home button has worked
完成的
The home button and logic board not matching should not lock down the phone to the iphone screen. People use new iphone buttons all the time and just don't have identity capability. There has to be a solution.
完成的
The computer fell off the motherboard. I tried to reattach it and put conductive glue on the cable but it did not work. Please give me a solution
完成的
The small motherboard on the flex cable of the button fell off during repair and I tried to put it back together, without any luck. I tried to scrape and glue the flex cable with conductive glue, and scraping. Still no go
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
My bet is on (missing the original home button) being the culprit. Put it back and try again.
这个答案有帮助吗?
得分 1
6条评论:
I can't. It was torn in half on the flex cable
完成的
The home button itself or the cable that connects it from the screen to the board?
完成的
I can't. It was torn in half on the flex cable. What else can I do?
完成的
Nothing. No original home button = restore error. I'm speculating, but if you have abother phone, give it a shot by connecting an original screen with home button then restore. Would this solve it? Although I highly doubt it. Home button and logic board should be matching.
完成的
The original home button was damaged. I put the screws in the correct place
I put them exactly in the place that they went
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Shannon Bradford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 8,896
