跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Can a PS4 overheat
I'm not sure if a PS4 can overheat. When I turn it on its really hot but the more I play on the PS4 it gets cooler. Its not in a small space (that's what I think at least) sides are open but the backside is at least 5 inches away from a wall. I'm not sure what to do I need answers please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
12条评论
My PlayStation is overheating, but it only happens when I start playing Black ops 3. What should I do?
完成的
My PS4 has been having this problem recently as well every few days. Despite the outside vents being cleaned with a vacuum (I know this sounds like its probably bad for the PS4, but it works for me) and not having much dust on the outside it still happens. Just today I put my PS4 to the home screen for 20 minutes after playing COD Warzone for a few hours and when I chose the application: The Last Of Us it gave me the message to turn it off because of overheating when the game was still loading. I've noticed that when Im playing most games, the fan is very loud, but the PS4 isn't too hot, which is unlike when Im on the home screen where I cant hear a fan, but my PS4 becomes hot. Any advice would be greatly appreciated :)
完成的
Wow I think this website actually helped me see I have the Same problem it gets hot and I start to worry and its in my book shelf idk if I should movedmoved it or not.and if it shuts off from overheating what shall I do
完成的
How do I turn off the notification of system overheating so I don't have to see it ever again because it's getting annoying even know when my system is not overheating
完成的
What if you put a cool van by it to cool it down will that help or not cuz my has not beep and it in rest mode would that cool it down too or not
完成的
显示更多的7条评论
添加一条评论
13个答案
最有帮助的答案
Yes, a PS4 can overheat. If it does you will see the red light come on and it will beep three times and shut off.
If it is just hot and the fan is running high, that's normal if you are playing a game that requires a lot of CPU/GPU power.
It sounds like where you have it is just fine. I would check to be sure that the vents are not dirty or plugged. If it's not dirty and it gets plenty of air flow then I wouldn't worry about it...especially since you said it gets cooler as it runs. This doesn't sound like anything to worry about.
这个答案有帮助吗?
得分 5
9条评论:
Thanks for the information. I play GTA5 most of the time, that might be the reason
完成的
No problem...yes, that is probably the reason!
完成的
Hi,I just read the above comment, well I have a ps4 original 3 years running...but now any game I decide to play the internal fan blows really hard,to the point of annoying and can't hear my tv....it all seem to start when I bought red dead 2...paid 80 bucks for the game and can only play for around 5 minutes at a time because of fan issues...what's the problem here?
完成的
It is due to the dust that is collected in the vents or the fan get that cleaned up the ps4 will sound normal.
完成的
so i have a similar problem. and i cleaned every where i could on the ps4 specially the fan and the vents. but it still makes a loud noise and over heats when i play call of duty warzone. only over heats with that game i can't figure out whats going on. also the bottom of the console seams to get really hot when it over heats.
完成的
显示更多的4条评论
添加一条评论
The ps4 is overheating because your ps4 has dust built up in the inside plus if you play for majority of hours
这个答案有帮助吗?
得分 3
添加一条评论
How long could you keep your ps4 on until it overheats?
这个答案有帮助吗?
得分 3
2条评论:
5 second when I load up a modern warfare multiplayer game. But works perfectly fine with any other game
完成的
You can keep youre ps4 on for like days , the next gen console is meant to be active for a long oeriod of time
完成的
添加一条评论
The ps4 has no overheat limit, it overheats when the ps4 can't run a certain game
这个答案有帮助吗?
得分 3
添加一条评论
Yes it does. Any electronic can overheat. I hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
My playstation overheats so much i cant even open a game it shows a message on the screen that my ps4 is overheating and then when you click ok 3 seconds after it shuts down i tried cleaning, air conpresor ,vacuum and it still overheat. My ps4 is not even hot either i check it and its cool i even have a fan and my window is open (its winter). I dont know if its a bug or anything but i dont see anyone else online with this problem and i !#^&@! me off. Whats the point of having a gaming console if i cant even open a game.
这个答案有帮助吗?
得分 2
添加一条评论
Yes the ps4 can overheat
这个答案有帮助吗?
得分 1
添加一条评论
For me .When I play it gets hot when I play for around 15 or 20 minutes.But when I knew it is because of the dust I cleaned it then when I started to play it worked but after 25 minutes it became hot
这个答案有帮助吗?
得分 1
1条评论:
whatrgyhukijuyhgtrfdfghjkl;polikujyhtgrfdcfgthynjmuk,l.o,ikmujyhgtrftgyhujkjuyhtbgvrf
完成的
添加一条评论
OK so this is normal It just might be that after your done playing that you will turn it off and it will heat up but over time when you turn it on it gets cooler because the fans on so this is totally normal make sure your room isn’t to hot either that will really affect it.
这个答案有帮助吗?
得分 1
添加一条评论
You got to clean the fan in the PS4 and if that don’t work then the PS4 is on it way out so try
这个答案有帮助吗?
得分 0
添加一条评论
No, you don’nt need to clean the invest fan of the ps4 just for cleaning all u have to do is use a vaccum hose to clean the ps4.
这个答案有帮助吗?
得分 0
添加一条评论
I have found out, that playing on disc can cause overheating, I played war thunder(discless game) for 8 hours straight not a problem, the next day after an hour of DMC5 it overheats. What’s happening is when u start playing on a disc game the disc spins around and all that $@$* and it just takes more power to run disc rather than discless games. That’s for me anyway. But I did see a guy on here say he was playing warzone good then the last of us is what did it, I bet he was playing the last of us on disc, or maybe this is just a solution that works for me I dunno. Oh and my PS4 has been used a lot I got it day 1 the release day and the PS4 still worlds amazing downloads take 10-20 minutes longer maybe even an hour because of the dust and stuff but an xtra 10 minutes ain’t too bad. And my internet is really good so that’s why I don’t care only took me like maybe 16 hours to download war zone which back on my old wifi would have easily taken 2 weeks but now I’m free of that sh*t. Yes 16 hours is still quite a bit of time but the game is like 100GB’s. Anyway in conclusion PLAY DISCLESS ITS BETTER and u don’t have to change disc each time u wanna switch game.
这个答案有帮助吗?
得分 0
添加一条评论
A PlayStation 4 can overheat like: Hot, Fan high mode, PS5 meets a ps3 to help a ps4
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Felix Mendoza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 32,765
