跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Front facing camera shutter stuck?
Hi,
I'm having some real issues with my phone at the moment. I've just done a screen replacement and just as i thought all was finally fixed, i went onto the camera. It first appeared to work fine (this being the back facing camera) however when switching to the front facing camera the shutter doesn't open at all. Here's a picture of it :
It's annoying as always when you fix it, another thing happens. I'm not too sure what's happened with the camera as the phone wasn't in working condition when i bought it, so it may have been not working before i got it. It just seems to be the front camera that's gone wrong somewhere along the line.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
UPDATE: Just replaced the front camera and that hasn't worked!! I now have no idea what to do..
完成的
添加一条评论
2个答案
已选择的解决方案
First make sure nothing is obstructing the camera on the new screen that you installed: remove the camera and look against the light.
If that's not the issue, use a magnifying glass to examine the board mainly next to the front camera connector, but also next to all the other connectors in that area. Let us know if you find something missing/damaged/corroded.
这个答案有帮助吗?
得分 1
添加一条评论
Make sure the front camera cable is properly seated on the mother board. It also possible that the cable was damaged during the repair and may need to be replaced.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your reply. I've checked and it seems that the camera connections are connected to the phone fine. I tried taking it off and on again ,but no luck. I've just ordered a new front facing camera now so hopefully it'll work! Thank you
完成的
添加一条评论
添加你的答案
Stewart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 208
