跳转到主内容
加入维修社区 - 创建账户
The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
I have antifreeze coming form the exhaust
I have a 1997 jeep cherokee sport. It was over -heating due to a cracked radiator..So I replaced the radiator and still overheating. I than took off the thermostate and now I have antifreeze coming form the exhaust...HELP what is this...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
why do you think it is anti-freeze?
完成的
添加一条评论
2个答案
最有帮助的答案
In best case you have just blown head gasket... In worst cracked engine block or head.....
这个答案有帮助吗?
得分 1
添加一条评论
Look at you're oil cap ware you put oil in and If you see like a frothy look to it you probably have a bad head gasket you can also look at the dipstick and if its higher than what its supposed to be you probably have a head gasket problem. If it is a head gasket when you take the head off take a really straight and flat peace of meateal and go slowly across the head in all directions and if you see any gaps even a little one take it to a machine shop and have them shave the head otherwise if you just put a new gasket on it will still leak also look for cracks . You could have them preasher test it as well it should all cost about 60 or so.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
smilez 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 15
总计 431
