跳转到主内容
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
50 个问题 查看全部
Is my dark orange (vs amber) power adaptor light causing freezes?
My 1 GHz Tibook started erratically freezing mostly when on battery power. I also noticed that the charging light on the power connector is now a darker orange rather than amber.
Is this my imagination or a diagnostic tool?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
It's hard to say with these old Titaniums. The battery itself is unlikely to cause a computer to freeze. A computer running on battery power will have trouble coming out of sleep mode if the battery is close to dead, but actual "freezing" of the computer due to a battery is something I haven't experienced.
Titaniums are increasingly becoming flaky, and they do generally have motherboard issues at this stage in the game which cause many of them to randomly freeze. It might be solved by a DC-in replacement, if you want to explore that route.
I would also verify the memory slots by putting RAM in only one slot or the other, and resetting the PMU and PRAM after each change...sometimes this can "jolt" a laptop into working again, and, who knows, you might find that one of the memory slots has a problem, and that the laptop works fine when the bad one is empty. It does happen fairly often.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
The light is probably just your imagination- unless the charger is getting old and not functioning well. How old is your battery? You may need to calibrate or replace it.
这个答案有帮助吗?
得分 1
1条评论:
They do actually turn a darker orange - i have seen it myself
完成的
添加一条评论
添加你的答案
Tim Schellenbaum 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 12
总计 1,570
