跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
20 个问题 查看全部
Upgrading the SSD, will it be compatible?
I scrolled through the comments and saw that the required ssd m2 for this laptop (xps 13 2015) would be 80mm NOT the 60mm ones.
So will http://www.amazon.com/Samsung-850-EVO-3-...
Fit in perfectly and run perfectly with the bios and stuff?
My new to upgrading ssds. Would it be as simple as plug and play?
It is currently running ( samsung pm851 with 128gb)
Thanks in advance
Sheldon
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
完成的
添加一条评论
2个答案
已选择的解决方案
Yes. I just completed this exact upgrade just minutes ago. I got an external M2SATA to SATA adapter/enclosure at the same time I bought the new SSD (http://amazon.com/gp/product/B00SM0M5QC?... - enclosure instructions were horrible). I put the new SSD in the adapter and connected it to one of the laptop USB ports using a SATA to USB adapter I already had (http://www.microcenter.com/product/35793...). I wanted to retain the GPT partitioning with the support partitions and found the Samsung Data Migration software inadequate to do this (at least one partition was not recognized). I also looked at EaseUS ToDo, which also did not appear to have the needed capabilities. MiniTools Partition Wizard Free Edition (http://www.majorgeeks.com/files/details/...) performed the migration well. I did a disk clone keeping all partition sizes the same, moving the last, ~7GB, partition to the end of the new drive and then resizing the C:\ drive to consume all of the new space. The clone process took ~1 hour, with a reboot needed to clone the boot partition; I ended up with a 457 GB C:\ drive.
这个答案有帮助吗?
得分 3
2条评论:
Can I just insert it then and clean install Windows from a bootable usb? I don't have a sata to usb convertor.. And I don't need those filss
完成的
I would certainly think so; I can't imagine a scenario in which it would not.
完成的
添加一条评论
The XPS 9343/9350/9360 has one of the best SSD slots I had seen ever. It does not matter if it is PCIe/NVMe/SATA. They all run very fast. As long as it fit, the computer can recognize it and you can put whatever you want on it.
___
Formatting and initializing the drive can go as easy as Windows Disk Manager, or DISKPART for more advanced users.
Macrium Reflect is very powerful if you want to clone sectors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yong Sheldon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 6,144
