跳转到主内容
Introduced in 2012, the Gaems G155 is a portable gaming monitor that can support the Xbox 360, or the PS3. While there are multiple versions of the Gaems monitor, the G155 is the most sold and common.
A Bad Day at The Black Watch...nothing but Snow
ok,
so i replaced the screen following this iFixit guide (great guide BTW),
powered on,
but all i get is a bad day at the black watch. nothing but snow.
any ideas, do i need a remote to change the input to hdmi, as i bought it with the cracked screen sans accessories.
or could there be a problem with the control board, all the buttons work, sound from speakers briefly until the mute kicks in. initial startup shows the Gaems 'G' logo on a black background, which hints that the screen is good.
thanks
nae
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
What I did to resolve this issue was unplug the display and wait for the red light in the power button to disappear then wait about ten seconds to plug in back in then turn it on. Repeat if necessary
这个答案有帮助吗?
得分 1
1条评论:
Do you happen to have a link confirming this fix? I'd love to mark your answer as accepted ;-)
完成的
添加一条评论
there is nothing you can do. you've bought one with the known channel change bug. i think the guy, where you've bought it from, did used an universal remote and accidently changed the channel to one that is not the hdmi channel. i wrote to gaems and there is no known way to change it back to hdmi. i'm sad to say, but i think your g155 is scrap.
这个答案有帮助吗?
得分 1
4条评论:
i thought about trying a universal remote but no code worked 100% so this info makes sense. it's a shame Gaems can't be bothered to investigate a cure though as im sure this can't be an isolated incident.
i have however ordered a lcd driver board to replace the original as its too good to scrap.
on a lighter note it would explain the cracked screen, previous owner used a universal remote, locked channel because of bug, got mad smacked screen
完成的
Hi I was just wondering which driver board did you order? Thanks
完成的
is this a real thing? couldn't find any other reference to that online...
完成的
Yep it is indeed. I live in N.ireland and have worked at 3 of these. 1 with the channel change problems (now parts) and 2 with faulty back light and speakers. Pos and gaems are as useful as an ashtray on a motorbike. 'Have you tried using a new power adapter' etc zero warranty outside the USA.
完成的
添加一条评论
添加你的答案
nae10271 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 1,008
