iPhone 5s: Apple logo and then black screen - after screen replacement
Hello, I have an iPhone 5s that goes to a black/blank screen but first the Apple Logo comes up. I replaced the screen on it, I've done hundreds of screen replacements before without a problem. I'm always careful with electronics since they tend to be very fragile (anti-static wristband and no metal tools). I tried searching up the issue on several other forum with no luck, I figured I could give it a shot to see if anyone else has come across this. The iPhone doesn't go to DFU mode or recovery mode, it simply reboots back to Apple and then to black/blank screen. I tried forcing it to DFU mode with RecBoot as well without a luck. I'm assuming it's a board issue but wanted to know if anyone knew what I would need to replace. I'm comfortable doing SMD and good with a soldering gun. The display comes on fine, it's not faded or lacking brightness so I doubt that it's the LCD capacitor but I really don't know. Hopefully someone can help with this very weird problem. Thank you for your time!
-If anyone has a link for a application like recboot that works, that would be appreciate as well, Thanks again!
1条评论
Is the board getting hot anywhere?
由 Jason Gan 完成的
