跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s: Apple logo and then black screen - after screen replacement
Hello, I have an iPhone 5s that goes to a black/blank screen but first the Apple Logo comes up. I replaced the screen on it, I've done hundreds of screen replacements before without a problem. I'm always careful with electronics since they tend to be very fragile (anti-static wristband and no metal tools). I tried searching up the issue on several other forum with no luck, I figured I could give it a shot to see if anyone else has come across this. The iPhone doesn't go to DFU mode or recovery mode, it simply reboots back to Apple and then to black/blank screen. I tried forcing it to DFU mode with RecBoot as well without a luck. I'm assuming it's a board issue but wanted to know if anyone knew what I would need to replace. I'm comfortable doing SMD and good with a soldering gun. The display comes on fine, it's not faded or lacking brightness so I doubt that it's the LCD capacitor but I really don't know. Hopefully someone can help with this very weird problem. Thank you for your time!
-If anyone has a link for a application like recboot that works, that would be appreciate as well, Thanks again!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Is the board getting hot anywhere?
完成的
添加一条评论
3个答案
最有帮助的答案
You seem to know your way around the phone. I hate to suggest it but have you tried to use a different screen to see if it's just a bad part? I've had a few of those lately (mainly on the 6 and the 6 Plus) that seem like they are working, but they either force the phone to constantly restart or they do what yours is doing, and they just bootloop. It's rare but if you bought the screen already prepped, it could be the front camera causing the restart if it's a bad part. Worst case scenario you can try the broken screen on it to see if that still works, assuming the LCD didn't blow on it.
Wish I could be more helpful, but they best of luck anyway!
这个答案有帮助吗?
得分 1
1条评论:
I've tried several other screens, original and after market. All it does is hangs on Apple logo as if it was booting but then suddenly turns completely black. No sound or vibration upon switching vibrate switch on and off. It's very odd. I'm sure it's something to do with the board but wanted to see if anyone knows what component to switch out since I have spare bad boards to take components out from.
完成的
添加一条评论
i have solved this problem , just change the LCD and rostore the phone via itunes .
这个答案有帮助吗?
得分 1
添加一条评论
This usually happens with a faulty battery or battery connection. The phone has enough juice to power the display but as soon as the other components start to online the phone crashes and attempts to start again. Try a new battery and verify the connection from the battery to the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fidel Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 16,417
