Replacement of hard drive with larger capacity cause issues?
Hello! I need to replace the HD in my iBook G4 12" 1.2GHz 30GB HD. I'm looking at buying your IF107-069-1 (320 GB 5400 RPM Western Digital ATA Hard Drive). If I replace my HD with a larger capacity HD will I loose any functionality?
Also, is there a larger or faster RPM HD for sale for this model? The reason I ask is because I once tried to replace the HD in a G3 iMac with a non-approved HD and that iMac would no longer go to sleep.
2条评论
Colleen, thank you for the prompt response!
由 Stafford 完成的
If Colleen's answer helped you, you should accept the answer. If you're still not sure of a resolution, at least vote her post up.
由 Kyle Wiens 完成的
