跳转到主内容
HD action camera with touchscreen LCD, released October 5, 2014.
87 个问题 查看全部
I dropped my gopro hero4 onto a hard floor.
I dropped my gopro 4, now it will not turn on or charge. Once I picked up the unit after dropping it, the rear lcd screen was kind of glitched out also. It wouldn't turn off(the screen) so I took the battery out, ever since, it's been dead.
Anyone got any ideas as to what might've bunged out in this thing, what might need replacing or any other ideas?
Cheers.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I'm not sure about the Hero4. Is there anyway to reset it? If yes, this should be tried first.
If there isn't a way to reset it, or reseting did not solve your issue, then can you place a known good charged battery inside your GoPro and see if it works.
- If the GoPro works with a charged battery BUT does not charge, then either the charging port or the charging circuit on the board are damaged.
The charging port is a pretty straightforward repair that nonetheless requires a professional with the right tolls and skills.
The charging circuit, now that's a different story.. special skills and tools are needed also, and the right type of experience in trouble shooting fixing those things.
- If your GoPro does not run on a charged battery, then something in the board's circuit has been damaged.
Repairing a faulty board that doesn't start is not straightforward; and finding and fixing the issue will rely on the skills of the repair tech and the extent of the damage.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
krismoit 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 1,838
